sjcolu
sjcolu
Default Re: rtv 900 costly rear ujoint repair
I just did thistwo weeks ago. Jack up the rtv and place two jack stands in front of the 2 rear leafs on the supports. place floor jack under rear axle not to lift just for support. remove all nuts from jeaf spring perches (both sides). remove band clamps from inner boots. slowly lower axle now twist the rear axle left to right to seperate the splines from the inner shaft to the outer.these splines only line up one way when going back, to make it easier before seperating take some paint marker and scribe a straight line across both shafts where they connect this will make reassembly very easy. now that the shafts are seperated remove the three bolts holding the inner shafts to the transmission, place a catch can under both sides to catch the trans oil. I lost about half a gallon. take a thin blade screwdriver and remove plates from side of trans, shaft ,bearing and u-joint will all come out as one.To answer your question reassemble joint on inner shaft on both sides then with some pivoting left and right align splines on one side then the other and finish reassembly.Hope this helped</p>
sjcolu
