@ETF Did you look at this thread? He's having an ant problem. Maybe you have some insights.
RTV 2" receiver mounted broadcast spreader
Here is my dilemma: I got fire ants. I need to broadcast some fire ant bait over about 7 acres of grassland. I have found a electric broadcast spreader with a 2" receiver mount with a variable speed electric motor for the impeller. I am going to mount it on the back of my Kubota RTV X1100C...www.nettractortalk.com
I've love to see a pic of your set up. Are you using the same herbicide you mentioned in the other thread? What is your mixing ratio? Maybe start a new thread for this. Would be great info.I mow at 3".
Today is herbicide day. 25 gallon sprayer behind the ATV. Almost done but the wind picked up so taking a break.
Our timing just sucks. I was using the sprayer this afternoon, just got done spraying, got everything cleaned up and put away, came to my computer and found this.I've love to see a pic of your set up.
Don't have time right now for a new thread.Are you using the same herbicide you mentioned in the other thread? What is your mixing ratio? Maybe start a new thread for this. Would be great info.
For the lawn and my recent spreading of weed killer, I'm trying something new.Are you using the same herbicide you mentioned in the other thread?
Thanks. I may need to switch if what I just applied doesn't work out.I’ve had good luck with Trimec 992 for weed control in my yard.
