If my switch arrives tomorrow, and it looks like it will work the way I plan, I’ll install it and take pictures and post. Fishing the wires to the dome light was quick and easy so I am hoping that the location I have in mind will work well.![]()
The suspense is killing me.![]()
Sorry to disappoint! The switch arrived, but it was not long enough - the dimensions given in the description were not complete and I gambled and lost. I've ordered another that should be here next week. I spent considerable time today trying to figure out how I can use the one that came and the only places that make sense to me are the place where ZMan placed his and where I want to put mine just to the left of where ZMan placed his. Mine (if I get a switch that works there) will be on the plastic so I don't have to drill out the frame. While I doubt drilling out the frame will compromise the integrity of the frame I just want to hold off on that if I can. I did look at the place you suggested - next to the cup holder, but routing the wire looks to be too much trouble. I didn't see an easy way to get a wire to the headliner. I'll study this some more. The switch I ordered now is: https://smile.amazon.com/gp/product/B09N8WJLSK/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&th=1
I'll be back as soon as I have more to report.
I noticed that the doorjam switch was hitting the weather strip at an angle and was starting to rip it, so I reinstalled it near the cup holder as talked about above. I drilled above the brace for the switch and screwed into the brace with the mounting screw/ground. I did run the wire along the windshield weather stripping. I did have to shorten the switch a little. It works perfect now.
ZMAN - that looks great, but I don't fully understand how you concealed the wiring and how you fished it into the headliner. Thanks for clarifying. I had wondered how you prevented the switch from compromising the weather striping where you originally placed the switch. That was one other reason I decided to not use that spot.
Thanks for the quick reply. Next time I am working on my machine I will investigate further. What year is your machine? In your first photo your machine has an unpainted threaded bracket with an orange surface (or is that orange reflection?). I assume that in the third photo I see the wire as it transitions to the headliner??Not the greatest pictures especially since I'm using a brown wire. It's tucked between the post and windshield gasket.
Dave
Hi Dave, good for you - sounds like a nice system. It is like the improvement I made with the wiper system. Unfortunately, I can't seem to load the video, but I certainly can appreciate how it works. I'll report back with what I end up doing after the new switch arrives next week.I decided to finish up the dome light switch and delay project today. It's setup to turn light on when door is opened and slowly dim out after 5 seconds after door is closed. It also will turn light on when you shut ignition off and shut off immediately if door closes when ignition is on. I also set the door open timeout to 10 minutes in case "someone" doesn't close door completely. Attached is a crappy quick video of it in action.
Dave
My problem playing your video is that I live in the woods and have only a very slow DSL connection and it took a few minutes to download your video - it finally did. Looks terrific. Nice work. CongratulationsLet's see if my video works.
Dave
