Usually the guy who contracts to maintain and harvest my orchard starts the annual cultivation by going through with a flail mower. This is to shred the pruning debris that didn't make it to the burn pile, as well as to make the grass decay so it will be easier to disc under later on.
This year he has contracted to run too much acreage and says he is way behind. He asked if I would hit it with my 4ft mower now that I have a smaller Yanmar that fits under the trees. This took a while, using such a small mower.
I like this little Yanmar (YM186D). I bought it for the small size, to fit under the trees, but more important because the Powershift transmission is what I need for these variable slopes. Moving the column shift grabs the next gear instantly without losing inertia.
The older part of the orchard with wide open rows is easy. Then going the other way to cross-mow means slowing and climbing the terraces between rows.
Down in the modern semi-dwarf trees that are planted closer, and are on steeper ground, climbing each terrace is an adventure. I stopped here when there was no clearance to ride the tractor under a low limb. I shifted to low range (tiller crawl) then got off and stood to the side, and shifted the column shifter (Powershift) to 1st. At an idle, low-low is *real* slow, way less than walking pace. The steering wheel and seat barely cleared the limb, about an inch space.
Note the chain between the quick hitch and the mower. I set that up to make slack, to hinge going up and down the terraces. I also offset the mower to the right to get the tractor farther from the trees.
The place looks almost civilized after its mowed.
I didn't get a good picture that shows my 'cupholder'. It's an insulated backpack that I slung off the side of the hood to carry a 2-liter bottle of chilled water. Some of the weeds were as high as the tractor.
![P1590065rMow3.jpg P1590065rMow3.jpg](https://www.nettractortalk.com/forums/data/attachments/0/834-89fc8de14668a260f0f7bfb979c791fd.jpg?hash=ifyN4UZoom)
