Slaw32
Yeah , sorry I didn't take more pictures of the process , but I can try to explain how I did it with the pictures I have . In the first picture look closely and you can see that I put dynamat down over all exposed metal and plastic . I used the original Matt as a pattern and i cut the dynaliner and the thick rubber Matt from that pattern . I used 3 m traction strips over the dynamat in the vertical surfaces . Look close and you can see that the foam dynaliner is on the floor only and the traction strips on the rest . In the second picture you can see the rubber Matt on the floor , the dynaliner is under that . Then look at vertical surfaces and that is where the traction strips were put over the top of the dynamat . Clear as mud??
