I installed a turbo kit from turbokits.com on my X1100C. It is a totally different machine to drive now, it will still stall the engine on a hard pull in high gear without the hand throttle being pulled, but in low gear it will spin all four wheels from idle. It climbs without bogging down, or going to a crawl, with more adjustments to the hydro unit it will probably go over 25MPH, but since I did it for more low end power I'm not to worried about top speed. The install was a lot more than bolting on a turbo, the timing got changed on the fuel pump, the injectors got turned up, the max engine RPM increased slightly, and two pressure adjustments in the hydro unit. I'm running a max of 10PSI of boost, I also installed a pyrometer to monitor the system, it tops out at 1100 degrees when under enough load to produce 10PSI of boost. The attached picture was taken before the turbo got wrapped in a heat blanket.
