Well aparantly I havecreated quite a stirr... Thats ok though. Glad to be joined and a new member though to your forum. Itake a lot of pride in my work andwant to assist in others problemshowever that I can.</p>
So on this post, obviously the problem is getting out of gear. Only two things that cancause this issue are hst neutral adjustment or the dumpvalve is not working or adjusted properly. Hst pressure is the cause for not shifting out of gear, other than internal binding in the transmission (which I have never seen) Idle speed, blipping the throttle, turning the steering wheel, and even the release knob are just a cover of the real problem to get the unit to shift. You shouldNOT have to do any of that on yourunit if it is set up correctly. I see a lot of people refering to turning the steering wheel to reduce the pressure and allow it to shift. What you are actually doing is moving the machine with the front wheels when you do this and that causes the pressure to be takin off the transmission, allowing you to shift. The power steering on an rtv has its own dedicated circit (pump, reservoir, lines and cylinder) and is in no way connected to the hst on the machine, so by turning the wheel you are not relieving the pressure in the hst. The older john deere tractors use the main pump on the front of the engine for the entire hydraulic system, which is a variable displacement pump, and causes direct load on the engine during startup, to turning the wheel on them is often the only way to start other than shutting the pump off. </p>
First you want to check that the hst is neutral when the machine is in gear. If you jack and block the machine in the air, put the trans in hi range and rev the engine to maximum by the throttle lever on the injection pump (not the foot pedal) the tires should not move at all. If they do, the hst neutral needs to be adjusted. I will post up some pictures of the rod that you need to adjust to do this. It is very sensitive, and will take a bit of fiddling, but when perfect it will fix the shifting issue.</p>
If the hst is set to neutral correctly, and the machine is shifted properly, there will not be any issue. I always tell customers, take your time, be patient. Most of the time just pause when you stop on a hill, step on the brake pedal firmly and hold it there for a 2 second count, then shift out of gear. It makes a big difference, just try it. This of course is still assuming that the hst is set to neutral properly. If there are any more questions or concerns, dont hesitate to ask me.</p>
