Good. Glad to hear that. That is what I was guessing and hoping it most likely was. No prob. I was planning to top off the tank anyway.Doc I have a trail that is about a 14% grade. If I am under half tank, mine will sputter same way. On flat road, I can run it down to one bar no problem. Its only when I am on that real steep trail that leads to a ridge top orchard.
Hope that helps.
With all our hills I think that is a good plan for me to follow also.One of our x1100’s dies at 2 bars on the gauge. First time that happened it was a 2 mile hike to the truck for fuel. Now we make sure we don’t go under 3 bars.
that sounds about right. i also gained 3 mph with larger tires. from 20 to 11 probably about right if the hill is steep. sounds like your hst is in good shape also. probably could up the fuel just a tad and give it a few rpm to 3650 no load but really your pretty good.Yesterday was a good day for a ride. I had to get diesel fuel so I loaded up the cans in the RTV and set off. I also found a GPS app for my phone, speedometer. A free app that will show your GPS speed. Since putting on larger tires the top speed I was seeing was 20. So I thought I needed some major tweaking. With the GPS app I saw a top speed of 28, and easy to get to 26 mph. On hills where I thought I was dropping to 7mph I was really going 11. I did drop from 22mph to 11mph on the longest steepest hill. That is still a huge drop in speed but I feel better knowing I am not dropping all the way to 7mph.![]()
My x1100c speedo was right on with factory tires. When i replaced the tires with a larger radius i also increased the real speed by 3mph but my speedo still reads the lower speed. I checked and the difference is all across the range.Thanks Aurthuritis. I do feel better about it now. Has anyone else noticed such a big discrepancy between GPS speed and digital speedo on the RTV x1100c?
Mine is a 3 MPH difference also.Thanks Aurthuritis. I do feel better about it now. Has anyone else noticed such a big discrepancy between GPS speed and digital speedo on the RTV x1100c?
Were those speeds from your digital dash speedo or GPS?Doc I did some benchmarking today and on Meigs county township roads I cruised along with two adults, one of whom is a former tackle and linebacker and managed about 20mph just taking it easy. On moderate hills, I dropped to 15mph. On substantial hills, I dropped to 11mph but pulled hard. I am running 26 inch blackwaters and was in high gear. Hope this helps.
yup. bigger tires more distance per revolution changes the ratio equals more speed as long as you have enough power to overcome the leverage.Were those speeds from your digital dash speedo or GPS?
I have 27's on mine and for the life of me could not understand how that increased my top speed. The tires are bigger and heavier than what was on there before. I guess it's due to circumference. Each turn of the center the outside edge goes faster. And the further from the center the faster you go. I think I answered my own question. Does that sound right?
Would you be interested in meeting on Success Rd or Joppa and we could do a run to Forked Run State Park area. We are not allowed in the official park but we run the side roads around the lake. Some beautiful views.
I've done that and it drops way more than 2mph. more like 5.If there's enough run room , try to start out with warm machine at about 12 at bottom of hill , hold it to the floor . Shouldn't go below 10 at the top .
