Kubota RTVX Rear LED Worklight
I paid 16 bucks through amazon prime for the ones I just showed.If I put them all together up front i m thinking they would be just as bright as my front lightbar I have mounted under the roof and paid a hell of a lot more money for that...
PS someplace in all of my postes there is an image of the lightbar im just to tired to look for it.One day when it warms up a bit ill shoot a video of all of the lights and strobes on.Looks like a spaceship going down the road when i have everything on..
Nothing like fixing a flat when its 15 degrees out.Froze my tail off and have a migrain but needed it fixed to get fire wood up.If anyone has thought about a manual tire changer from harbor freight i recommend it highly.Saves you 20 bucks a pop on flat tired and love mine.After I get my head to ease up ill take some pictures of the new LED alley lights and hopefully will have the backup light installed so i can take a picture of that too.
Have a good warm day as lord knows im not lol.
Bummer about the flat. Lights look like they work well. On the flat tire side of topics, I have a Coats 210 manual rim clamp tire machine for motorcycle and ATV tires. It works very well. I don't recall the cast but don't remember it being over costly.
I got mine from Harbor Freight while on sale for 39 bucks it will change all the tired I have here including my truck tires if need be but i purchased it strictly for the RTV tires instead of dropping everything and hopint the tire place is open.Seems most of my flats come on a sunday for some reason and now i can have it pulled fixed and replaced in abour 1.5 hours instead of waiting a day or so to be fixed.
http://www.harborfreight.com/manual-tire-changer-69686.html
Thanks for the link to these 48W 4" square spot LEDs.
I need some lighting for my RTV900 while plowing snow - - do you think 4 of these mounted in front would be a good choice or perhaps a single light bar?
Thanks for all suggestions!
I think 4 would do a good job and be cheaper than a light bar. But a light bar would look neater. I have neither right now, but I'm thinking of going the cheaper route.
Thanks Doc - I'm thinking the same.
Specs say each spot draws 2A @ 12V - that's 8A draw for all four. Any good suggestions for a wiring harness/switch to go with this?
Here is my 50" led light bar... I bought it off Amazon. Installing it was a breeze and it's super bright... it was my father's day gift...
That is one BIG light bar, I bet is very bright at night. Looks good and is impressive for sure.
Tim
WOW - that's a great looking bar!
Got a link ?
I'm concerned about the added height to get in my garage.
thank you! I really don't think it added much height to mine, due to the downward slope of the roof...
https://www.amazon.com/dp/B00FH8P1DG/ref=cm_sw_r_other_awd_JiEWwbS6Z0HYG
Tim
Oh it is. I've used it a whole lot and it's super nice...thank you!!!
Thanks for the follow up link - I was also looking at that beast as a possibility.
question - what did you do for a wiring harness - - looks like it is 300W, that's a lot of power
Thanks
Thanks
I found a wiring harness on Amazon that said it supported a light bar that large... so far haven't popped a fuse or a relay... it's worked very reliably...
here is one showing the mounting positions of my new lights while i had the damn machine burried right befor i had to go the the tractor to pull it out.LOL Trying to plow out the chicken coupe area it sunk in the snow and it was sitting on the frame.
New lights look GREAT. Nick job.
I resized your pic for easier viewing I hope.
What is that other thing on the back? 2nd pic is of it.
Ah that is my air intake from the home made high rise air intake.That was the part that originally sat on the [passender side inside the plastic.I removed it from there to use as the intake piece.Someplace on these threads there is more images of the conversion and thanks for resizing it I thought i made the image small enough but maybe i uploaded the wrong image.
