For those of you who have had the problem I have had with the factory installed Jensen HD radio losing the programed station button selections, I have figured out a good solution. I changed the harness pin location so that the radio is now wired into the constant on (green/white) wire in the switch panel below the radio. I spliced in a rocker switch so now I can turn off the radio there and so far after a week of using the switch I have not had to reprogram the station selections. The radio now can work with the ignition off! It is nice to pull into a worksite and be able to listen to the radio or Pandora, etc. without the ignition switch on with the panel lights, etc. glowing. Evidently when the engine is starting there must be some interference (glow plug operation??) that erases the station memory. Didn't happen all the time but frequently enough it was a annoying.
