RTV Console Finished..
Well, I finally have pretty much finished my homemade console. The cows and nice weather has made it a long time in coming since I do my paying job first and my "habit" last. It was a lot of fun but exasperating not having the time to finish it for so long.
I have several pictures showing the way it can be mounted to the front roll bar with the clamps somewhat loose - allowing it to hang downward and making it easier to hook up the wires. Everything is very tight room wise so if you should decide to make your own, do a dry run because those bolts on the roll bar do stick out and so do the indentions in the plastic roof. Everything went like clockwork though-only having to turn around one of the front bolts in the ROPS that was a centimeter too long for my ends. It was fine then.
I appreciate having my weather radio back(fm also) I had it in the dash of the '05 and speakers under the hood of it. I also like the binocular bin. I think it will be real handy for my small binoculars and a note pad/pen. I ran separate wires to each work light , the radio , the sprayer hook ups in several locations and the sunglasses/light combo. I still had a couple of the 8 switches I didn't hook up The switch panel wiring was in two sections so I put each section on a fuse so I could run several things without blowing one. The map light in the sunglass holder is nice and has its own switches but I wired it with the switch panel because it was there and simple to just plug it into the panel. I will still use it's push on switches but it will only be powered by the main switch if the control panel.
So basically , I had the radio and wood for the console and had just bought the control panel anyway so I mostly have less than $30 in the 5 clamps, $22 in the sunglass holder, $10 paint , the resin and whatever else I forgot about. The already bought switch panel was $50 or 60 . This is going to work for me just fine and I hope that if you attempt this , that you will enjoy it as much as I intend to. I like saving $$ so I am willing to have a homemade looking console. Heck, it works and I've got some change in my pocket.
Good Luck, bordercollie
edit: I will be replacing the wing nuts with just nuts because those things hurt if you hit em with your head. Mostly though it is out of the way
collie
