I installed the factory hand throttle on my 2016 X900, the results are not quite what I expected
In high range going about 7mph I pulled the hand throttle out, the machine downshifted to low range.
I'm a little dense at time but I was expecting the engine speed to increase without the transmission hunting for a higher gear ratio.
Is the downshift normal or did I screw up installing it? ☺☺
That is not normal. If you pull the hand throttle and the engine speed does not increase (as you expected), then something is definitely wrong.I installed the factory hand throttle on my 2016 X900, the results are not quite what I expected
