Oldhand
I hardly ever post on this forum but I'm going to chime in on this. Acetylene becomes unstable above 15# when in a gaseous state. It is desolved in acetone when it is still in the bottle and is stable. Acetylene should never be used from a bottle laying on it's side as that draws acetone from the bottle. Acetylene shouldn't be be used from a bottle that has been laying down until it has stood upright for 30 minutes.
Oxygen by it's self is not dangerous. It promotes rapid combustion of flammable materials though is why you have to be careful. Never use oil or grease around high pressure oxygen as it can lead to an explosion as seen in the video.If you just have to lubricate something on an oxygen regulator use soap. Clean and dry is best.
When cutting I always set my regulators at 10# acetylene and 40# oxygen and use that unless I'm cutting metal over 1/2" thick. It saves steps back and forth to your bottles. Those little valves on your torch are regulating devices as long as your tip is not plugged and can be used to set your flame. You can feather your cutting oxygen lever for the thickness of metal you are cutting also. I cut 16 guage to 1/2" plate with a 00 tip and those pressures. Above 1/2" I'll increase tip size and oxygen pressure for the thickness of the material. I'll also increase acetylene pressure when using a #4 cutting tip or a big scarfing tip.
The pressure in a bottle of acetylene varies a great deal with the temperature. I have seen a full bottle register 375# pressure on a summer day when the temperature is over 100 degrees. I've also seen a full bottle only show 140# when the temperature is around 20 degrees. Acetylene bottles are filled and measured by cubic feet, not pressure. Oxygen bottles are filled to 2200# pressure maximum and doesn't vary a lot by temperature.
That's the way I've always used them. Actually, don't remember ever having the acet. over 9-10.
Used to braze a lot of carbide tipped tooling, cutting plate, etc.
