My door does not seal correctly. On the drivers side, at the top,,in the rear corner. The frame looks like it was bent incorrectly at the factory. The radius on the cab is pushed out. This makes the seal on the door and the cab headliner, not fit. I can live with the liner,,,but the door lets snow and rain in the corner.
After staring at it,,,,I think the best fix is to heat up the corner of the plastic door,,,,bend it out (uncurl the edge) so it would reach out farther,,,then bend the tubing in (if needed) to press the seal against the frame.
What I want to know,,, has anybody ever taken a heat gun to the plastic door? Will it soften and bend? Will it crack or discolor?
If it has been done and it is easy,,,,i would rather not go back to the dealer.If not easy,,, I want them to break the window, not me.
