TWO GUNS
You're not using wheel spacers (to widen vehicle stance) are you?
NO Sir:
No wheel spacers. Just ITP rims and tires .....
............ two guns
After seeing what Mark did with his Grim Reapers, comments from other members, and a long conversation with "Robin" at All Terrain. I felt the Reapers would do the job. I could not be happier. I would never load more then they have already carried many times (Firewood up to the top of the ROPS) The ride is way better then the new worksites, and I have moved tons of snow (Usually in two wheel drive) With the factory worksites I was always going the Dif. lock or 4WD. Now it will go where it will scare you in 2WD. Maybe if I was hauling 1/2 ton of rock every load every day, I would look at the Kendras but I'm very happy with the choice I made. (26 x 10" front, 26 x 12" rear, on 2013, 900 XT
I would never disagree with being safe. And Will Rogers had more common sense then all the modern worlds politicians put together~~~~~~
I'm kinda wondering why your tires are beyond your flares Two Guns. I have ITP rims and 12" wide Reapers on the rear(Your tire are different but the cross section should be about the same.) Mine are at least one inch inside the flares. The only time I get flying mud is from the front tire on a tight turn.
Jamie,
Do you know the offset of the rims you're using? I wonder if they're off by an inch compared to OEM.
