2014 RTV X1100C will not move. Hydraulic Oil foaming, HST? Transmission?
Hi Cooper sorry for the late response. for some reason I didn't see this notification. But yes you're correct exactly the alignment marks on the gear were not on the same side.
Graham,
Is that the only trick with the charge pump? The alignment marks just need to be on the same side? we had the charge pump apart the other day, and I saw the alignment marks, but wasn’t sure exactly how to orient them so we put it back together exactly as we found it. In our situation, it turns out the input shaft that rotates the charge pump has failed. Just checking this for future reference.
Thank you....
