doggman
Doggman, I got to thinking today of a buzz sound that I did notice when I first got the '11. (I had forgotten about it) I heard this noise that was somewhere between a vibration and a buzz. It was the seat belt mechanism . It will vibrate at a certain pitch when the conditions are just right. I put my hand over on it and that was the sure enough the source of the noise. I will try to think on this and see if I can come up with anything else I have just become accustomed to. bordercollie
Bordercollie, I have the metal roof (FOPS) and it does squeak when I'm rolling over uneven terrain like a ditch. I haven't tightened the bolts yet but that might help. I seem to remember that the 2005 had some rubber mat or belting material on the underside of the FOPS.
I'll have to check out the seat belts - it never occurred to me that that might be the source of the buzz.
All in all the new trans makes the RTV even more impressive - it pulls like a Willys in 4WD! (I'm still not used to the geared down reverse, though.)
I just bought a new 53 HP Hydro Kubota tractor. There are more bells and whistles on the transmission than I'll ever use. But one of the nice ones is that there is a small dial knob on the panel where you can easily adjust the braking action of the hydro trans. There is also a shuttle type feature on the steering column where you can shift H, M, or L into a fast or slow mode even under load. It's kind of like an overdrive lever and turns the trans into 6 ranges instead of 3. Anyhow, I bet we'll see those types of features incorporated in the RTVs sometime in the future.
