Kubota
2017 RTV-X1140
1074hrs / 6798 miles
I have WSM RTV-X1140 (Rev. Date 08/21) (PN 9Y111-09968)
History:
Purchased at auction, was used by a construction company.
Maintenance:
Generally, looks to have been good, all grease fittings I looked at were freshly greased. Oil & hydraulic filters had Hours & Date written on them and were close to the 1070hrs on the Operator screen.
Condition at purchase:
The motor would start and run.
The unit would not move forward or reverse.
The transmission level showed good on the dip stick.
But also I found that there was almost no hydraulic fluid in the tank under the seat.
During the filter change I found that the big filter (Suction?) was loose, and that would explain why it leaked every time the engine was started.
Current Status:
Laser Tach - https://www.amazon.com/dp/B0765XP9LS?psc=1&ref=ppx_yo2ov_dt_b_product_details
Test Kit - https://www.amazon.com/dp/B07HQ3CZ1B?psc=1&ref=ppx_yo2ov_dt_b_product_details
Here is my plan, I will be detailed, and as I am an engineer, it is a habit.
I hope the experts on here can give me direction if they see something I am not going to do correctly.
The plan:
Or does it make since to take it down and look at the brass plates, pump, and motor?
If in specification, I will go forward with the following test, and evaluate the data.
Have I missed something?
I look forward to everyone's input.
Thanks and have a great weekend.
2017 RTV-X1140
History:
Maintenance:
Current Status:
- Drained the hydraulic tank and replaced the two Hydraulic filters with new Kubota filters. Refilled the tank. Yes UDT2.
- Jacked the rear end off the ground. Placed in 2wd and started the engine and allowed the oil to circulate in neutral for about 10 or 15 minutes. Could see it circulating in the tank under the seat.
- I then put it in high and slowly depressed the peddle, until I was “Full Throttle”. The rear tires started to turn, and it would get to about 13 mph. reverse to 9 mph. I did this a couple times.
- Changed the filters again. I cut the filters open to check for debris and found nothing. Very clean with no metal fines or anything.
- Replaced filters and topped off UDT2. Drive turns rear wheels when lifted with jack.
- No change in drive, RTV will not move when on the ground and tried in forward or reverse.
- Hydraulics for the steering and Bed work fine.
- I have looked at the Engine Cable, and there is slack or droop in the cable, and the HST linkage will move some before the throttle lever even starts to move. The throttle lever at full throttle, has about 1/8” from lever to throttle stop screw that is wire tied fuel control valve, after the foot peddle is against the stop. I attached a couple pictures.
The plan:
- Verify the engine RPM with the laser Tach. I think I can get a piece of the reflective tape to stick to a flat on the crank nut. I don’t plan to remove all the plastic covers, and I can see the nut from above. If there is a better location, let me know.
- Check Charge Relief Pressure (Page 2-S6)
- Engine Speed - 1400RPM
- Oil Temp – 120°
- Document Results (Spec: 63 to 120 psi)
- If I see no Low pressure here, I may not go forward and just know I must do a full teardown and evaluation.
- Checking High Pressure Relief Valve Pressure (Traveling Side) (Page 2-S7)
- Apply Parking Brake
- Place in “H” Gear
- Engine Speed - Maximum while transmission stalling.
- Oil Temp – 120°
- Document Results (Spec: 3560 to 3980 psi)
- Checking High Pressure Relief Valve Pressure (Dynamic Brake) (Page 2-S8)
- Remove the neutral rod (HST control rod) (3) from the HST control lever (4).
- Place in “H” Gear
- Oil Temp – 120°
