Well? If it were mine i would change the oil and filters just to rule out the easy stuff first. Check all of the suction lines and fittings for air leaks. Before you change the oil look at the oil in the hydro tank before you start the engine and after setting over night. Pull a sample with a 20cc syringe and a short tube. Examine and set aside or put the sample in a small clear container. Then run the machine until it begins the shutter and repeat the draw sample. Compare the two samples to see if the oil looks milky of has tiny bubbles in it and report back what you find.
