Strobe light kit on RTV-X900
hellasmania
I installed the Kubota strobe light kit today. I have the plastic canopy and glass windshield. After drilling 4 holes and using included rubber grommets, the install was easy. The kit came with a lighted switch and the wires were encased in the ribbed wire sheaths. I have the multiple accessory wiring harness as well. Next project is to get a set of rear LED lights installed. Just thought I'd share.
Sounds like it went well.
Kubota does an excellent job of putting together option kits for all their products. Rarely hear of any issues with the installs.
Nice.
Again nice job..Do you have any pics of the inside of the cab ..wiring and switch?
Just a reminder... Once you put that light on top, you won't fit under a standard garage door (6.5' ?) anymore. When I first put my lights overhead, I wouldn't always remember but I did set mine up as a magnetic mount so it just slid when I hit the door frame. ;)
Same issue, I went with strobes around the perimeter of the canopy instead.
Here is a picture of the switch for the strobe. It is lighted and indicates on and off position by another level of illumination. I ran the wire up the drivers side Rops and curved around back. Ran the wire to under the strobe on the plastic roof. I have the rear work LED light on order and will post back with that install.
