G
<span style="font-size: small;"></span></p>
<p align="left">
<p align="left">HYDRAULIC DRIVE PUMP MODULE: </p>
</span><span style="font-size: small; font-family: Wingdings,Wingdings;"><font size="3" face="Wingdings,Wingdings">
<p align="left">?? </p>
</font></span>
<p align="left"></p>
<span style="font-size: small; font-family: Arial,Arial;">Hydraulically-driven through RTV900’s Remote Tool Circuit </span>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">(NO GAS ENGINE!) </span></p>
</p>
</p>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">Model 5CP6120-EJM Triple Plunger Pump </span></p>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">Water flow & pressure = 6.0 Gallons per Minute @ 1,600 psi </span></p>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">Chrome-Moly Crankshaft </span></p>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">Shaft Protector</span><span style="font-size: small; font-family: Wingdings,Wingdings;"></span></p>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">Oversize Bearings </span></p>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">Stainless Steel Valves and Valve seats</span><span style="font-size: small; font-family: Wingdings,Wingdings;"></span></p>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">Brass Manifold</span><span style="font-size: small; font-family: Wingdings,Wingdings;"></span></p>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">Die Cast Aluminum Crankcase</span><span style="font-size: small; font-family: Wingdings,Wingdings;"></span></p>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">Inlet Eductor </span></p>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">Inlet Strainer </span></p>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">Pop-off Pressure Relief Valve preset
</span></p>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">Thermal Relief Valve-prevents overheating of bypass loop </span></p>
<p align="left">OPERATOR STATION MODULE: </p>
</span></p>
<dir><dir>
</dir></dir><dir><dir>
<p align="left">
<span style="font-size: small;"><font size="3"><dir><dir></dir></dir></font></span><dir><dir></dir></dir>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">70-gallon Polypropylene Water Tank
</span></p>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">5-gallon Foam Tank
</span></p>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">Triple Nozzle Foam Gun; Straight stream, fan spray, foam mixture stream
</span></p>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">High Pressure Attack Hose, 3/8" x 150ft, 4000 PSI, resistant to heat,
<p align="left">cleaning chemicals and wear </p>
<font size="3" face="Arial,Arial"><dir><dir></dir></dir></font></span></p>
<dir><dir></dir></dir><span style="font-size: small; font-family: Wingdings,Wingdings;"><font size="3" face="Wingdings,Wingdings">
</font></span>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">Hose Reel with Motorized Pay-In
</span></p>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">Operator Control Panel with foam agent rack, regulating unloaded, pressure gauge, on/off foam agent valve and reel switch
</span></p>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">Maximum Water/Equipment Payload 1,100 lbs
T</span><span style="font-size: small; font-family: Arial,Arial;">otal System Weight (Pump & Operator Station combined)= 438 lbs (dry, no foam or water)
<p align="left">SERVICE, TRAINING & WARRANTY (via E.J. Metals for Assault Force 70): </p>
</p>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">Service DVD for rebuilding pump fluid end
</span></p>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">Service Manuals and data sheets
</span></p>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">Technical support via technical sales and support group
</span></p>
<dir><dir>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">Warranty: one year parts & labor </span></p>
</dir></dir></p>
</p>
</dir></dir>
<p align="left">OPTIONAL EQUIPMENT: </p>
</span></p>
<dir><dir>
<p align="left">
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">Kubota Hydraulic Tools: V6290 250gpm Sump Pump, V6210 Chain Saw, V6200 Breaker, etc. (available through Kubota dealer)
</span></p>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">2500lb Warn Winch installed on front of unit (Kubota dealer-install)
</span></p>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">Whelen LED Warning Light Package (EJ Metals install)
</span></p>
</font></span>
<dir><dir>
<p align="left"><span style="font-size: small; font-family: Arial,Arial;">Fire Research Corp Optimum HID12-volt 150-watt fixed work light (EJ Metals install) </span></p>
</dir></dir></p>
</p>
</dir></dir>
</p>
</span></p>
<span style="font-size: small; font-family: Arial,Arial;"></span></p>
<p align="left">
</font></span>
</p>
</p>
</span></p>
</span></p>
<dir><dir>
<p align="left">
</span></p>
</span></p>
</span></p>
</font></span>
</span></p>
</span></p>
</p>
</span></p>
</span></p>
</span></p>
<dir><dir>
</dir></dir></p>
</p>
</dir></dir>
</span></p>
<dir><dir>
<p align="left">
</span></p>
</span></p>
</span></p>
</font></span>
<dir><dir>
</dir></dir></p>
</p>
</dir></dir>
</p>
</span></p>
