Battery was going bad so I installed a new (Interstate) battery. Prior to the new battery, everything worked. After new battery, no electrical power when after turning key. Cleaned some corrosion on the negative terminal. Checked all fuses with VOM. On starter, power tests 12 volts with VOM (I put the VOM on the negative battery post and the VOM positive on the starter). Frustrating in that battery appears to be making contact but there is no life to the gauges or starting lights. It acts like there is an open/broken wire coming from the battery positive post to the electrical system.
