RTV x1100c shakes at idle - mid rpm
dtreid
New to me rtv x1100c. Starts great. Runs great down the road.
Problem is that the engine shakes quite a bit at idle up to about 1/2 rpm. At full throttle it's not noticable.
I swapped out the injectors and injection pump delivery valves with another engine and it made no difference.
Any suggestion?
dtreid
Idle rpm is set correctly. I have several other of these machines and this is the only one that I've had this issue with.
Ok. So you have put a tach on it and confirmed? This has been a problem for years for just a few. The idle set to low at factory. The symptoms are exactly as yours. Could be a bad or improperly installed harmonic ballancer
