Ok, I got the adapters installed tonight.  What a major difference in being able to see and adjust the mirrors.
This is a view of what you could see on the passenger side.  Partial top was totally blocked and you couldn't get it adjusted to be able to see more of what was behind you.  A lot of the cab frame was blocking the view.
This was best view you could get out of the drivers side.  Just not acceptable.
This is why you couldn't adjust the mirror up any more.  The factory option tubing was at an angle.  If they had made ir flare horizontal right at the end, you could have adjusted the mirror a lot more up, down left and right.  As you can see, the swivel socket on the top was maxed out, so you couldn't get the mirror tilted up anymore.  Even if you could, as high as the mirror was sitting, the roof would have blocked half the view.
Here it is with the factory mirror removed, looking at the threaded hole at the end of the bracket tubing.
Here is the mirror with the new HeliMod bracket and the metric screw that came with it.  Easy assembly.  Just screw the mirror into the threaded holes and then tighten the jamb nut until it is good and firm.
Here the factory mirror is re-installed on the bracket tubing. Notice the angle of the Helimod bracket is straight up and down now.  Also, the bracket lowers the whole mirror about 4 inches.  The ball socket is now sitting centered, giving you full capability to now adjust the mirror up, down, left and right.
Now look at your view from the drivers seat.  You can now turn the mirror horizontal if you want a wider view instead of a taller view.
Wide angle view.
Here the RTV X1100C sits with the Helimod brackets installed.  You couldn't ask for a better rear view in your mirrors.  The factory mirrors and bracket are a good quality product, they just didn't prototype it and try it out before they rushed it to market.  If they had, they would have found sub-standard mirror view and would have done something else with the mounting bracket to make it work the way it should of.
The adapters are made of solid 3/4" CNC billet aluminum and then heavily powdered coated to prevent corrosion.  I'll post a link if anyone is interested.
					www.helibars.com
