Just as Onfootsaid,the post is not really that clear, BUT, I can say, if it is not in the red, you are just fine !!!! The Temp guage like to have drove me and others crazy !!!!!</p>
KEEP YOUR RADIATOR CLEAN,Pick up the seat, pull the mest out,clean it and spray out the radiator. Now, just becouse you think your meshis stopping ALL the debris that can clogg up the radiator, you are wrong, gotta keep the flums of the radiator cleanalso, most tries to settle to the bottom end of the radiator. Clean from the top to the bottom ..... take a look at this link < http://compacttractorreview.com/cs/forums/p/3110/14534.aspx#14534</p>
Kubota a few years ago changed the temp sending units, one that took different OHMs to register on the guages. So that made the newer models look like they were running hotter, but actually not, just looked that way .... Like said before, if it's not in the red, it's ok !!!!
Also, your radiator fan will be cycling on and off during your running, which will show that everything in running fine ~~~~~~~~</p>
<div class="ForumPostTitleArea">
<h4 class="ForumPostTitle">RTV TEMP INFORMATION </h4>
<div class="ForumPostButtons">
<table cellpadding="0" cellspacing="0" border="0">
<tbody>
<tr>
<td></td>
<td>|</td>
<td></td>
<td>|</td>
<td></td>
<td>|</td>
<td></td>
</tr>
</tbody>
</table>
</div>
</div>
<table width="100%" cellpadding="0" cellspacing="0" border="0" style="table-layout: fixed; height: 100%;">
<tbody>
<tr>
<td>
<div class="ForumPostBodyArea">
<div class="ForumPostContentText">
Ran across this information the other day while at my dealer looking at some equipment ...</p>
He let me take a look threw his RTV book, and ran across this, thought I would write it down and pass on, since several of us wanted to know the running temps of the engine >>>></p>
<span style="font-size: x-large;"> Thermostat</span> ----<span style="color: #ff0000;"> <span style="font-size: x-large;">Valve Opening Temp At Beginning</span></span></p>
<span style="color: #0000ff; font-size: large;">176.9 - 182.3 F</span></p>
<span style="color: #ff0000;"> <span style="font-size: large;">Valve Opening Temp ( Opened Completely )</span></span></p>
<span style="color: #0000ff; font-size: large;">203 F degrees</span> </p>
<span style="font-size: x-large;">Radiator Cap</span> -------- <span style="color: #0000ff; font-size: large;">13-9 psi</span> </p>
<span style="font-size: large;"><span style="color: #9acd32;"></span><span style="color: #ff1493;"> Pressure Falling Time ----- 10 seconds or more</span></span></p>
<span style="font-size: x-large;">Oil Pressure</span> ----------- <span style="color: #ff0000; font-size: large;">At Rated Speed</span></p>
<span style="color: #0000ff; font-size: large;"> 28-64 psi</span></p>
<span style="font-size: large;"> <span style="color: #ff0000;">Allowable Limit</span></span></p>
<span style="color: #0000ff; font-size: large;">14 psi</span></p>
<span style="font-size: large;"> <span style="color: #ff0000;">At Rated Speed</span></span> </p>
<span style="color: #0000ff; font-size: large;"> 21psi</span></p>
</div>
</div>
</td>
</tr>
</tbody>
</table>
</p>
>>>>>>> two guns >>>>>>>>>>> </p>
