RTV-900 rear differential Problem
Pop205
Newbe to these forums. I have read a lot here over the last several years, but have just now joined so I could ask a question.
I recently replaced the u-joints on the rear axles of my 2007 RTV-900. I now have a squeaking noise (sounds like something binding) in the rear of the machine, and the machine feels like something is holding it back. I jacked the back end of it up to see if I could tell what was wrong, I could manually turn (in neutral) the left rear tire, the right rear feels as if it is locked. I removed the rear axle assembly to try to see what is going on, and can't find any bad u-joints or bearings every things is tight but turns easily. I put the axle half of the right axle back in the differential but I can't turn it by the u-joint.
Any ideas on what may be causing this?
Thanks for any help in advance!
