Couple of other things-
The two RTV's I have are later models with the 4 bolt valve cover. The cover has a rubber gasket that (so far) seems to be re-usable. It'll probably stay in the cover when you pull it off. Just leave it in there. That way you'll save a few bucks, or if you bought an upper-end gasket kit you can save the gasket that came with it for a later time, like when you need to adjust the valves or re-torque the head bolts. I've had mine off several times each, and no leaks yet.
And speaking of valves, you should adjust them after you put the head back on. It doesn't take long to do- if you do it right, you only have to turn the engine over once. I don't remember the exact sequence off the top of my bald head, but if you need the info I have it in my manual at work. You're gonna need the torque spec for the rocker shaft bolts as well. It's a lot easier to access the head bolts without the rockers in the way. And don't forget to keep the pushrods in order since they're wear-matched.
And there's also lash caps on the top of each valve. They just sit there, and they'll fall off if you manhandle the head too much. They can drop into the engine or somewhere else where you can't find 'em. Better to take them off and keep them in order before pulling the head off.
Kubota says to just keep cranking it until the engine starts in order bleed the air out of the injector pump and lines. That's fine if you're only changing the fuel filters, but trust me, you'll be there all freakin' day if the injectors and pump are dry. I cracked the compression nuts on the injectors about a turn loose, then cranked it until I saw a little fuel leaking out of the top of each injector. I tightened up the nuts, cranked it, and she fired right up.
I'm not trying to sound like a know-it-all, I'd just like to save somebody some time, money, and aggravation. I got nailed by a seized (then broken) glow plug and the water outlet thing in my other post, and it cost a chuck of time and money. The Kubota dealers don't stock any parts that aren't popular, so a bad move can cost you days of waiting or a lot of coin for overnight freight.
