I have a knock in my front axle. I replaced ball joint & both cv axles. Now when jacked up the right wheel turns easily but the left turns hard & makes the right tire turn backwards. Have screwed something up?
Do you have the two piece front drive shaft or the newer one piece drive shaft? I would check that before I started taking apart the knuckle cases. If the drive shaft is good I would start with the left knuckle case.
