DogDazeDave
I don't know what might be wrong. I tried everything I know to do. Water pump looks fine, belts are not slipping, fan is intact. Doesn't seem to be full of anything, stopped up or anything like that. Any ideas?
Same thing happen to my X900, removed floor board and found leak,Is there coolant in the reservoir? My two RTV's (2014 X900) and (2021 X1100C) both arrived with very slow coolant leaks that I initially saw via the level of coolant in the reservoir dropping slowly. I found two slow leaks where rubber hoses clamped on to steel pipes. Difficult to find and fix, but after that no more coolant loss. If I had not noticed early enough I would have seen a rise in the running temp.
