I have a 2011 model. i have tweaked many things for improved performance such as: adj throttle cables, both pedal and pump cables to obtain lower idle and higher wot speed. Did not touch fuel pump or screw. then readj servo linkage for better neutral. This smoothed shifting, just completely stop and return to low idle. Top speed is now 28-29 mph, all good here. I then adj and readj servo valve screw trying to improve hill climb speed and start up (wheel spin). Could not accomplish both so went with better hill climb. Will wheel
spin in 2wd low only when on hard dry soil.
Now for my cooling issue. When running on paved road and wot 28 mph I have about a 3 mile range before reaching the red zone in 90 deg ambients. I have checked the temp with infrared gauge and is pretty well dead on. Rad and air cleaner clean out is done frequently. So looking for a little more cooling. Have considered installing a low profile pusher fan on front side of rad in addition to standard and operate off it's own switch. Wondering if two of those hose billets (7" lg) installed in upper and lower hose would be enough. These are used on dirt bike/atv's when racing. Can anybody add some insight here?
So this is my first new thread, Thanks to all. Rogerw
