EZ, I don't know the answers to your questions. This was just one of those bits that gets spread around to help the techs diagnose things. I suggest that perhaps the water in the filter may have gotten there over a period of time, which varies depending on individual operating conditions. It could be the "shock" method (as seen in the above post) or it could be that something happpened over the past maintenance period, and the filter collected it as a matter of routine. </P>
Bottom line is, if you see a situation where your machine goes from a warm/humid environment to a cold one, and it shuts down, swap the filter. Also, take care to at least change the filter (hydro oilintervals vary from 200-250hrs depending on manufacturer) every 50 hours. </P>
Also, Since there are two filters, the filter in question is on the backend, on the hydrostatic drive unit. The one on the side is not only for the lift cylinder, but also has engine coolant immediately next to it in the small cooler.</P>
