MF 245 hydraulic filter replacement
adamprinsen
i have an MF 245. i want to replace the hydraulic filter. On the 135 i understand you remove the cover on the left side of the transmission case, On the 245 that cover has hydraulic hoses coming out of it as well and it looks like it could be more complex to remove. Is this the cover i have to remove? and is it tricky? what do i need to watch out for when i remove it? Thanks for your help!
I "think" the cover you need to remove is on the right side. It should be a metal plate with 3 bolts.
there is a metal plate with three bolts that i can access on the bottom of the tractor...underbelly of the transmission. I think there is a screen there i was told recently. i wonder if that is what you are talking about here too
Just what in the world are you on about here? He's not fooling with any hoses or connections.
Checking with Doc but I'm thinking Saarah is a spammer from India (and giving wrong/bad info). Up to Doc as to bring down the ban hammer.
