Hello everyone,
As the title says I have a MF 5445 year 2009 with the perkins engine.
I have a problem, on idle It spews a lot of black smoke and sometimes mixes white and blue. The idling is a little unstable.
At work, on the road when it is pulled it works perfectly go good without break down and no smoke.
Has anyone ever had a similar case?
I've done
- New Fuel Filter
- New Diesel Lift Pump
- Injector tested (Good)
- Turbo No gaps
- Put a endoscop cam in cylinder and all i saw was traces of diesel and in cylinder 2 the part of the head a little damp with traces of oil (this may explain the blue smoke but not so much)
I am now thinking about the injection pump, but I am Confused that there is only a problem at idle.
Thank you
I've done
- New Fuel Filter
- Turbo No gaps
Thank you
