I need an option on what would be the best tire for use on an 1100 with a lift kit that is operated on road most of the time. I know that the lift kit messes up the camber of the front tires and cause the tires to wear out on the outside of the stock 25x10x12. The 1100 belongs to my son that uses it in Montana on the road as a commuter to work and around town. You can really see the camber issue. I have a 900 with the lift kit and 26x10x12 Swamp Witch tires and it doesn’t seem to have the camber issue. Will a 26” tire help offset the camber or would it be best to remove the lift kit?
Thanks
Thanks
