Last summer I replaced the #896 halogen lamp with an LED replacement. I bought these off of amazon;
Link
I installed them last night and the difference is dramatic. The optics are correct and the beam pattern is spot on. Twice the light and a brighter color temperature. There is a tiny fan that keeps the lamps cool.
There was a minor modification that was needed. When I plugged the lamps into the wiring harness, they did not work. The polarity was reversed. This is pointed out on the website as a 50-50 chance of happening. The solution is to "flip" the plug, but they are keyed preventing this. The solution took only minutes. I removed the key slot on the wiring harness plug with a Dremel moto tool and a narrow wheel to remove the key slot in the plug. After that the wiring harness plug fit into the lamp socket with the correct polarity.
Antline Extremely Bright 50W High Power 881 889 886 894 896 LED Fog Light Bulbs Xenon White for DRL or Fog Lights (Packs of 2)
I was very disappointed. They are worse than the OEM lamps. Now that I'm working on dressing out the new 1100C, I found these from Alla Lighting. The model is 881-FL-BH-HL;Link
