Last year my Craftsman (Poulan) chainsaw wouldn't start. I couldn't get fuel to the priming bulb. Didn't mess with it until a couple of weeks ago. I bought new fuel lines, new primer bulb, new intake , fuel filter, and new intake & carb gaskets. The side was broken off the intake and the fuel line with fuel filter attached had broken off so I don't know which line it came off of.
There are 3 fuel lines on it. There are 2 inlets/outlets on the carb and 2 holes in the fuel tank.
One of the holes on the fuel tank is bigger than the other. I know this line connects to the primer bulb. I figure the smaller line on the primer bulb connects to the carb, but I don't know which barb. The other barb on the carb by default then has to go to the smaller hole in the tank.
Now when I bought the parts the guy told me that the little line going to the tank should be long and the fuel filter would attach to it. Not know which it came off of I said OK. I got it all put back together. I pushed the primer bulb several times, but I'm still not getting fuel.
I don't think I have the fuel lines hooked back up right or maybe the fuel filter not on the correct line.
I was able to get fuel flowing and was able to get it started for a couple of seconds. It would run wide open and as soon as I would unchoke it would die. Couldn't play with the throttle and keep it running, I figure I've got it bound up on something.. I didn't mess with it any more because I figure I'm fighting a losing battle with the broken intake. I'll pick another one up tomorrow and try it again. At least I'm making a little progress.
