Just need a mount, but I suspect the plow isn't wide enough. What is the width? 66" seems to be the minimum required for RTVs. Mine is 72", and I would prefer larger.
I have a similar Warn blade for my ATV. Mine has a plate that mounts under the ATV. For the RTV, you'll probably need a plate similar to what's pictured below. Disclaimer - I know nothing about this mount.
The big thing for me is the size of the plow vs the size of the RTV. The plow in your pics appears to be 48". The RTV is 60".
I had a similar mount under my ATV. My real question was does anyone know of such a mount for an RTV. i've never paid attention to how the blades are mounted on the RTV. I was hoping they were mounted in a similar fashion.
Understood the blade is not as wide as the RTV ...but if it was not to hard to mount I'd give it a shot since I have it. The other blades for the RTV I've seen are pretty expensive and hard to justify with the little bit of snow we get. Currently I push snow with a back blade on the tractor. It works, but being inside a heated cab would sure be nice.
