Hey guys I am new to the forum and pretty new to tractors, so I very much appreciate all the experience on this site. I am looking at a 2004 New Holland TC35DA at a dealer. It shows 940 hours but I am not sure if that is accurate. I looked over the tractor today and found a couple things that need addressing. The tilt steering does not lock in place, but instead slides back and forth. Is there an easy fix for this? Also, it is very difficult to pull the 4wd lever backwords to 2wd. This may be a result of the plastic panel over it being partially broken, not sure. Is the lever generally diffucult to pull? I also noticed the tach is not functioning correctly. I only drops to about 2500 when the tractor is off. When you rev the engine, it goes up from there until max, which is useless. I would imagine this is a cable or pickup as other things in the cluster do work including temp. Any suggestions. I did find some oil under the tractor about halfway back. Are there common leaks to look for. Finally, the AG tires are very worn. Does it seem reasonalbe to wear out a set of tires completely in 940 hours....not sure I trust the meter....Any idea on cost of replacent tires. I apologize for the long first post. Thank you in advance for your time.
Jason
Jason
