I have 3 Bush Hog garden tractors...two D4-10's and one JBI. The D's are gear trannies, the JB is hydrostatic and a much larger tractor. The JB is rarer than the D's, but I decided to alter it a bit beings I plan on keeping it till I die anyways. It came stock with a cast iron Briggs 14hp. I like more power. I also bought a Yazoo YR60 with a 2 cylinder Wisconsin TJD engine & the Yazoo as a complete mower just didn't cut it with our rolling barnyards...not hardly any traction. Thus the JB repower came to mind. Had to relocate JB's fuel tank to a fender box where battery was. Moved battery to other fender box as it wasn't a good fit for the tank, but fine for the battery. The engine fills the engine compartment. Had to raise dash unit & hood almost 2" to clear spark plugs. The stator in the TJD was toast, so machined a pulley to bolt to the doubleV pulley to drive a small Honda car alternator...plenty DC power now! The doubleV pulley is gonna drive the rear PTO shaft I am finishing up now. I have all the shaft in, but need to finish the belt tensioner system. This engine has GOBS of torque! It's gonna do great for mowing the barnyard areas...oh yeah, forgot to mention....the 60" deck from the Yazoo will become a pull behind mower running off the rear PTO shaft. Here's some pics:
Stock JBI
Engine fitting:
Fuel Tank in Fender Box
Lid I made from flat plate to match other...this side's lid was gone.
Pulley fitted to drive alternator
Alternator mounted
PTO Jackshaft Unit
Where pto shaft meets rear tractor chassis plate
Rear PTO output shaft
Here's a short video clip of engine running/driving.
http://s8.photobucket.com/albums/a3... Jabalina 1/?action=view¤t=MOV00088.flv
Stock JBI
Engine fitting:
Alternator mounted
PTO Jackshaft Unit
