I want to run electricity to a building on my property. It's about 150 feet from the power source to the building. I want to use a heavy gauge wire, enclosed in plastic conduit in a two-three foot deep trench. Unfortunately, the property sits on an expansive rock ledge so I might not be able to go that deep for the entire distance.
Anyway, is there a tractor implement I can use to dig this trench? I can probably rent a 'Ditch Witch' if I have to, but I already have the tractor. There will most probably be other trenches (longer distances) to eventually dig, so I wouldn't mind buying some sort of tractor trench digging implement if such a thing exists. Opinions and thoughts??
. Code would be 18" minimum. Gray electric conduit, not white plumbing pipe.
