I'm just guessing but wonder if it has air in the heater line... It may need "burping"?? This heats up from circulating hot water/coolant from the radiator and then a fan to blow the heat to the cab.Is this the type you have? Next, I would check the thermostat. also make sure that your rad is full still. But I am just shooting guesses around. Our old truck has a leak in the heater coil and you can smell coolant inside the cab.. Others will chime in soon. good luck, bordercollie
