15A rotary chopper part needed
JVT
the part number is C503E HUB
it is like a cap that slides over the wheel axle to hold it in place. it bolts to the outside and you remove it to let hub and wheel drop out for replacing.
it is heavy cast and a tight fit on the axle to hold it solid.
jd no longer makes it and i can't find any aftermarket.
the wheel assembly is on top of my chopper without the wheel bolted on. the part i need slides over the shiny axle after bolted in.
the auger in the chopper has been removed and may make it confusing to see.
http://
Have you checked Craigslist for your area? Not for the specific part per se but to find a whole chopper that's being parted out.
yes i have checked craigs. i know a couple farmers that have large scrap yards i'll be checking.
