Hi All, I had to replace my speed control plate on my 06 RTV 900 last fall. Since then, I have significantly less power (even on slight grades, M bogs down on hills i could do easily in H). On the plate itself, there are 3 screws, 1 for idle, and it is set good. Will adjusting the other 2 help at all with this? And if so, can any one describe the process (which screw) for adjusting? I am also open for suggestions other than these screws as well.
Thanks.
Thanks.
