Adjusted it up a bit more, cold I'm maintaining 3500psi at stall, bit less when hot, still lower torque than I think it should have. Doesn't lug the engine down (that is what I'm thinking is wrong), just slows speed down. Maintaining 3800rpm at stall. I have done the peddle and hst speed lever adjustment. Is there some other adjustment I can make to get the engine to actually work rather than "no load and slow right down" or is this normal? I have not tampered with the "smoke screw". It is the same in low range. Thanks
