power locations
Beerskie
Just joined the group, I have a 2016 Mahindra 2538 hst open station. I want to install a led lite bar, where (other than the battery) would be available power? Also I've heard there is a radio power source somewhere, anyone know this location? Thanks in advance for the help?
I don't have that tractor.
That said, for lights, look in your rear fender wells. There's normally a harness in there, probably with a quick-disconnect to power the fender lights.
Use a 12V tester on each wire to find the one that has 12V when you turn on your lights. Obviously, don't use the wire for flashers. If you don't already have a rear work light, there may be a spare wire in the harness for that light that you could use.
