Show us your tractor fuel storage and transfer set up.
Heres Mine.
http://i283.photobucket.com/albums/kk286/lb59/100_2303.jpg
Heres Mine.
It looks like you've done a nice job of piping on your tank, and I'm not trying to knock it, but I've got to agree with Dean. I have an outside 300 gal tank mounted on a steel support. I have the tank and support grounded directly to the ground with a copper grounding rod.Show us your tractor fuel storage and transfer set up.
Heres Mine.
One of the greatest things about the rig I set up is it eliminates the 2 worst things about using cans.Couple of Blitz gas cans spray painted yellow so I don't mix-em up. Nothing much to show.
I can do it either way.*I have the tank and support grounded directly to the ground with a copper grounding rod.
== == Do you transport diesel to the poly tank, or do you have it filled by a fuel service?
I was going to set my drum on a hand truck but this presented a problem with getting the full drum out of my pick up.
To heavy to run down a ramp from the tail gate and no way to get a set of forks under the drum to lift it off the truck with my tractor.
Instead of the hand truck I went with putting a tee on the inlet line of the pump and adding another hose to the tee this way there is no unloading a full drum off the truck. I just let the pimp do it.
This is one of the most clever features of my set up but I have to give the credit for the idea to a poster over on TBN.
I said I wouldn't post on this topic again but this bothers me and I'm going to try one more time!!
"UN3H1W". Means in essence: U.L. approved hose with static wire Molded hose brackets~~~~~~~~~~~~
lb59, I have known you remotely off and on for years and I really do not want any of you to become a statistic!!
Should you still be a doubting Thomas ask any heavy lift helicopter crew chief about STATIC Electricity and why he grounds the hook!!
Attaches to what?I agree...
You'll notice on my unit where the ground wire attaches near the bottom of the photo...
Paul Christenson has the /a great solution to this problem. This is the same thing I use. Wife got it for me as a gift. Works great. I attach the grounding cable first thing, before I do anything else. Later--Tom
