splitlogger
I have an rtv x900 and changing out the hyd. fluid and filters, yes all Kubota stuff. Since we have a dipstick for the trans. and one for the hyd. tank how much goes where? I know the capacity is 2.6 gals. but where does it ever state the trans holds this amount and the hyd. tank holds this much? I'm pretty sure I checked at 1 1/2 gal, talking with a neighbor, and it did not register on the stick for the trans. When I put the rest of the two gals. in now it's about 1 inch over full on the trans stick. Then I put the third gal. in the hyd tank and it's still not full??? I'm guessing I need to drain some out and get the level down on the trans. but it will drain the tank also. What am I not seeing clearly?
